Question about a 97 bonniville
Old Aug 19, 2001 | 11:37 PM
HIX5000's Avatar
I was test driving one of the supercharged bonnivilles and noticed the boost guage at idle was at about -5 is that normal? What should it be at at idle? What should it be at under normal highway driving conditions? Thanx in advance for any help!
Old Aug 20, 2001 | 05:57 AM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
I don't know what the exact reading should be, but you won't have much boost at idle. There is a boost control solenoid mounted on the side of the supercharger, and the PCM will control the amount of boost, mostly for "load" type conditions. If you stomp on it, it should go up.
FREE CARFAX Record Check
If you live in Southeastern US, check us out!
South East Thirdgen
GM Master Tech
ASE Master Tech + L1
Savannah, GA
'87 Trans Am
S/D TPI retrofit including functional PassKey,
22# injectors,
Whatever chip I feel like burning,
JET AFPR, Ported Plenum,
TB Coolant Bypass, Custom Cold Air,
SSM SFC, KYB Shocks, Boxed LCAs, Wonder Bar,
8mm Accel wires,
Flowmaster Exhaust,
16" GTA rims,
Corvette Servo,
3.73 Posi
4wheel Disc Brakes
Summit 1-5/8" headers, 2.5" Dynomax catback.
Best 1/8: 9.519@72.74
'97 Bonneville SSE
Old Aug 20, 2001 | 05:04 PM
89IROC5.7's Avatar
Car: 89 IROC
Engine: 5.7 TPI
Transmission: A4
our gauge goes from -10 to +10. at idle, it is usually around -10 unless it is idleing high from, say, the A/C being on or something, then it will be a few pounds higher.at WOT it will go up to just short of the yellow line a little below +10. if anything seems wrong with it you may want to stay away from the car...our supercharger broke after a couple years, but luckily was under waranty because GM will bend you over for a new one. hope that might have helped.
Old Aug 20, 2001 | 05:07 PM
89IROC5.7's Avatar
Car: 89 IROC
Engine: 5.7 TPI
Transmission: A4
oh, missed part of your post. at nornal highway cruising, assuming you are just giving it enough to stay at around 65-70mph on a flat road- it will usually read around or just short of 0.
Old Aug 21, 2001 | 02:10 AM
HIX5000's Avatar
Thanks guys you were more than helpful.
fasteddi
Sep 10, 2015 09:32 AM
masonta
Sep 1, 2015 06:40 PM
Bubbajones_ya
Aug 31, 2015 12:02 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
