Can I do this column swap?
Old Aug 20, 2001 | 06:33 AM
86NiteRider's Avatar
From: Somewhere around the South Side of Chicago just crusin' in one of the Niteriders
Car: 92RS 25th Anniv./88 IROC Z28 Vert
Engine: 305 TBI w/Tpi Air / 305 TPI
Transmission: 700r4/700r4
Axle/Gears: Posi
Here's the deal. I can swap into my car an entire tilt steering column with the leather Camaro wheel for a standard column? The problem is currently in the car are regular wipers and the tilt column has intermitent. Is there a difference in the wiring? What needs to be rewired and does anyone have a diagram on them? Do I need to change the wiper motor also?
86 Camaro Black SS Coupe, T Tops, Flowmaster, Custom Paint, Dunlop Road Kings S/R tires, Wheel Country Directional Chrome Wheels,new charcoal & gray interior including seats and door panels, new carpet and headliner, complete front end suspension rebuild, new Valve seals, and more mods to come
http://www.angelfire.com/sports/niterider/86camaro.html
Morgan_Andre@hotmail.com
Old Aug 20, 2001 | 10:03 AM
formula90's Avatar
Car: 1990 Formula
Engine: 5.7 liter
just swap em man. no differrence in wiring. the harneses will connect wether you have all or none of the extras.the harness is the same. if you dont have cruise and things like that in your new column or the other way around, there will be more or less wires in the harness. it will still connect regardless. piece of cake
<font face="Verdana, Arial" size="2">I have experience......unfortunatly its a result of bad judgement......</font>
click below to check out....
www.formula350.com
or click below to email me
webmaster@formula350.com
Old Aug 21, 2001 | 02:20 AM
JoelOl75's Avatar
Car: 88 Firebird WS6
You will need to swap the wiper motor also, the intermittant is solid state and contained inside the motor housing. I'm not sure, but I think you will need to modify the harness some because there's extra wires needed, but they may already be there. Also some cars have the washer pump in the bottle, while others have it externally mounted... A wiring diagram should help (Chiltons book)
The column should swap right in no prob.
Jorlain
Aug 24, 2022 05:11 PM
Out-Cast
Mar 22, 2019 09:39 PM
Oenone
Aug 29, 2015 07:54 PM
Out-Cast
Aug 23, 2015 06:33 AM
Pemberton76
Aug 15, 2015 07:15 PM
