Non-Thirdgen - 1988 Suburban! Screwy no start.
Old Aug 21, 2001 | 12:50 PM
Red Devil's Avatar
Car: Tree Huggers
Engine: Do Not
Transmission: Appreciate Me.
Ok guys, here is a brain itcher.
1988 Suburban, 350 TBI.
Turn the key nothing happens. I have low beams, high beams, interior lights. Nothing else. You turn the key and you don’t even get the gauges to register or the fuel pump to spin, heck I don’t even have any dummy lights. With the key forward the radio won't turn on, however when you poke the wheel to get the time to flash, that still works (just like w/o the key forward).
Battery is good with a full charge, inboard fuses all good, and now get this… with the key forward, even though not a thing works, there is power to the starter solenoid.
What gives? Bad ignition switch? Starter relay? Fusible link? I don’t see a blasted thing in the engine compartment for any other fuses. Anyone have some experience with these beasts? I'm leaning toward the ignition switch but would love some input. Thanks!
"Question with boldness even the existence of a God; because, if there be one, he must more approve of the homage of reason, than that of blind-folded fear."
-Thomas Jefferson
Old Aug 21, 2001 | 12:54 PM
DualCarb's Avatar
could be a switch along the steering column, also check wires, I know I had a problem just like that with my fathers Van and it was a switch on the steering column!
Old Aug 21, 2001 | 01:02 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
First, check the fusible links. There are 2 battery feeds into the vehicle, about half of the circuits are connected to each; the ign sw even gets both of them, and some things are powered from each. I don't know where they are in a Submarine but a Chilton'e or some such ought to come in handy. If they're good, start tracing the big red wires under the hood from the battery toward the bulkhead connector; make sure the connector is good; then go around under the dash, and follow the big red wires everywhere they go.
ICON Motorsports
Old Aug 21, 2001 | 08:46 PM
Red Devil's Avatar
Car: Tree Huggers
Engine: Do Not
RB, you got it again. It was a fusible in the loom. Bitch to get at too. Thanks for the help guys!
Linson
Oct 24, 2025 02:00 PM
sheachopper
Jul 31, 2019 11:27 AM
RS Reaper
Oct 17, 2018 07:52 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
