engine id codes
Old May 20, 2005 | 06:52 PM
WaaX's Avatar
Car: 1985 IROC
Engine: 350 TPI (block was swapped)
Transmission: 700r4 w/corvette servo
Axle/Gears: no idea
engine id codes
I know this has been asked a few times, but I need to know where to locate the engine id code on my block, I have all the accessories off the front and I can see the front of the block plain as day, but I cant find any codes/letters/anything
I know that its somewhere in the rear drivers side of the engine, but I dont have access to getting to that as of yet.
I'm sorry if this is a repeat question but I did a search and couldnt find anything.
Old May 20, 2005 | 09:34 PM
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
www.mortec.com has all you need to know.
Old May 20, 2005 | 09:36 PM
Red Devil's Avatar
Car: Tree Huggers
Engine: Do Not
Transmission: Appreciate Me.
And once you read the mortec site and go back and look at your engine, you'll figure out that you don't need anything (but some patience on some) to 'get to it'. Good luck.
Old May 20, 2005 | 09:37 PM
AJ_92RS's Avatar
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
I don't know if Mortec points this out, but the last three digits of the casting number are also on the sides of the block.
I've been able to look up on the pass side of the block and see them, but it requires a jack (for us with "a little extra" in the waist area) and laying on your back.
I don't know if that's any easier than peaking down between the firewall and block though.
Old May 21, 2005 | 12:09 AM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
There's a pad on the block in front of the passenger head. Get all the numbers that are stamped on it.
Old May 21, 2005 | 12:31 AM
Petes 84Z28's Avatar
Car: 1989 Firebird Formula
Engine: Internal Combustion
Transmission: Completed
Axle/Gears: ones that turn.
Yep, and you can check the suffix code at http://www.chevymania.com/ and most times it will tell you exactly what the stock application and specs are.
Old May 23, 2005 | 12:35 AM
WaaX's Avatar
Car: 1985 IROC
Axle/Gears: no idea
thanks guys
Spyder_TheGamer
Dec 25, 2015 05:07 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
mizz0313
Aug 12, 2015 06:45 AM
