Heater Tubes/core (Guide/Sticky Please)
Old May 22, 2005 | 01:43 PM
Crusin' 1980's's Avatar
Car: 1988 SC Camaro
Engine: 305 TBI
Transmission: 700-R4
I have no heat comming from my vents and I'd like to clean/blow out the heater tubes/core, but I'm not sure exactly what/how to do it...there might also be a vavle that is/isn't opening that i can play with....is there a/can anyone write up a "sticky" to deal with this situation...it's a very common problem with cars that might be a relatively simple fix (DIY) that wouldn't require any special tools...any advice/info?...are there any guides on how to solve the "no heat" problem? Thanks
Old May 22, 2005 | 03:33 PM
Car: 1988 SC Camaro
Engine: 305 TBI
UPDATE: I found that valve that the heater/radiator tubes run through and it was closed....I opened it up and now I'm getting some heat from the vents...i still wonder if the core should be flushed...
Old May 22, 2005 | 03:38 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
I don't think flushing would get ya much, coolant circultes when in use...effectilvely flushing it.
Formula8r89
Sep 22, 2015 04:24 PM
BWilcox
Sep 20, 2015 12:19 PM
