Odd rearend noise
Car: 91 Camaro Z28
Engine: 5.0 TPI (LB9)
Transmission: 4L60
Odd rearend noise
Hey guys,
I just got my first TPI car, a 91 Z with the 305. This might be normal, but I kind of doubt it. When its parked, as in stopped and the engine not running and the key completely removed, there is an odd humming noise coming from the back of the car. It sounds like a deeper pitch than when the fuel pump primes the system when you turn the key on, and only lasts for 1 to 2 seconds. Any ideas what it could be?
Brian
Brian
Car: 89 IrocZ
Engine: L98-ish
It's normal for it to humm for a few seconds when you shut the car off...there's an oil pressure bypass switch that supplies power to the pump...so when you shut the car off the pump will still run until the pressure falls below 2-5PSI (unsure of exact number).
Now if it's humming all the time, might want to look at replacing the bypass switch...
If it's not the FuelPump, only other device I could think of is the hatch motor.
Car: 4
Engine: 6
Transmission: 5
It is not the fuel pump or the sending unit.
If you look just inside of the left rear wheel, you'll see a little plastic valve. That's what does it.
Only place to get one AFAIK is the dealer.
Want to guess how I know that?
Car: 4 Mopars total
Engine: Pentastar power
Transmission: T/F and New Process
Axle/Gears: Three 8 3/4's & one 9 1/4
I had the same thing happen on my 88 TA. Everytime you shut the car off after driving it, or even on warmer days....the car would just sit there and hum...much like a fuel pump. Everytime I would go over and loosen the gas cap, the noise would go away. Go to the dealer and buy a new relief valve.
Car: 91 Camaro Z28
Transmission: 4L60
Ok, thanks guys. Is this something that will/could cause me major problems? Cant afford to get it fixed right now ...
Brian
Brian
Car: 91 Camaro Z28
Transmission: 4L60
Ok cool, thanks. From my experience, the local GM dealers havent been very .... usefull in finding parts and getting them for me. Anyone happen to have a part number I can give them, or will they actually know what I need? THanks for the help guys
Brian
Brian
sjorgens
Oct 1, 2015 07:54 PM
