broken bolt in head
Old May 22, 2005 | 08:33 PM
DSmith's Avatar
Car: 1989 Camaro
Engine: 383
broken bolt in head
I had an exhaust bolt broken so I drilled it out, everything is good right? wrong
when I chased the threads I was felt it start to bottom out, begain to back the tap out and after about 1 turn the tap breaks off 1/8" inside the hole. This is not a straight tap, it has spiral flues. Its much harder than the drill bit so how do I get it out?
Old May 22, 2005 | 08:51 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
Easiest way is to pull the head and take it in.
You can make a guide, but would require you having access to the other bolt holes, a chuck of steel, and the ability to get it all in.
It's tough to explain via typing, but I've used 1/4 inch die grinder bits through a jig, got a decent surface, then cut out the tap.
You have to get creative and take your time...or pull the piece and have the shop do it.
Old May 22, 2005 | 08:54 PM
rsn932's Avatar
Re: broken bolt in head
I'm not familiar with this kind of tap. I'm assuming you can't use a tap extractor on it because it spirals somehow? Either way, spray lots and lots of penetrating fluid in there and try to get something down the flutes, either a tap extractor or some small allen wrenches and then turn them.
Old May 23, 2005 | 08:59 PM
DSmith's Avatar
Car: 1989 Camaro
Engine: 383
Thanks for the input, the head is off the car.
This tap looks a drill bit with threads, its used in cnc machines for higher speeds. instead of breaking spall chips off which would fall down into the hole it curles them out of the hole.
Old May 23, 2005 | 09:01 PM
rsn932's Avatar
That's pretty cool for tapping...doesn't leave you much for getting a broken one out though. Someone else must have some ideas...
Old May 23, 2005 | 09:07 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Maybe a pile of left-handed cobalt drill bits and a lot of patience?
Old May 24, 2005 | 07:59 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
You're lucky... i can't even drill into my broken exhaust bolt... i ruined 2 perfectly good steel-cutting drill bits on it.
Frozer!!!
Jan 19, 2024 04:55 PM
hectre13
Dec 11, 2023 08:14 AM
evilstuie
Jan 9, 2020 08:29 PM
355tpipickup
Aug 25, 2015 12:54 AM
