Spark Knock (DETONATION)
Old Aug 23, 2001 | 10:28 AM
johnyIROC's Avatar
How can you tell if you've got spark knock on a carbie? I am hearing some ticking at about 3 on the tack at WOT... I think it might be the rocker arms (I haven't set the valve lash yet)... I am going to set the lash and fill up with some better gas, and hope that it goes away...
Old Aug 23, 2001 | 11:59 AM
Grim Reaper's Avatar
Car: Death Mobile
Engine: 666 c.i.
The best way I can describe "ping" is that it sounds like a bunch of marbles are rattling around inside your engine. It is not a constant "tick" or anything like that; it is more "erratic". If you back off the throttle, it should disappear immeditately.
It happens usually under "high load" conditions.
Old Aug 23, 2001 | 01:52 PM
Brent's Avatar
Detonation will show up on the sparkplug insulators as blackish flecks (little fly turds).
RedLeader289
May 28, 2019 01:47 PM
bigjay89gta
Oct 15, 2015 08:04 AM
HoosierinWA
Oct 7, 2015 10:15 AM
meeklay812
Oct 1, 2015 03:46 PM
efiguy
Sep 27, 2015 01:30 PM
