ac delete
Old May 23, 2005 | 12:37 AM
WaaX's Avatar
Car: 1985 IROC
Engine: 350 TPI (block was swapped)
Transmission: 700r4 w/corvette servo
Axle/Gears: no idea
ac delete
alright, so im rebuilding my moter, since the ac doesnt even work anyways I took out the big radiator type thing, and cut off all the tubes and hoses and crap, now what else should I take off?
Im kind of confused on the wiring, I figure I should just not touch the wiring.
Old May 24, 2005 | 09:09 PM
NightHawk84's Avatar
Car: 1984 Trans Am
Engine: L98 350
When I took out the AC on my 84, I left the hook up wire from the harness. I took of the pump, hoses, and belt that ran the pump. Still needed the bracket though, but I'd say I lost about 20lbs or so and probably ~5 HP(or more, who knows?). Just as long as you keep the wire away from any moving parts.
jaridjohn
Oct 5, 2015 07:01 AM
djmarch
Oct 2, 2015 10:41 PM
Zell1luk
Sep 29, 2015 10:36 AM
