MSD 8225 or 8226?
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
MSD 8225 or 8226?
Just wondering what the difference is, and which one i'd need, i'm running a non-cc q-jet setup, with typical old school HEI.
I *think* it'd be the GM coil, 8226 ($77), rather then the HEI coil ($126)... but i'm a little confused, as I have a GM HEI....?
Also, think it'd be worth upgrading to, without any other real ignition mods?
Thanks -J
Thanks -J
Car: 1982 Trans-Am
Damn. ok, thanks, I just never noticed the "two prong" dealie on the top of my current coil...
Is this a worthwhile upgrade with a stock ignition module?
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Probably not unless your stock coil is bad. An aftermarket coil and module might not be a bad idea though.
RedLeader289
May 28, 2019 01:47 PM
sreZ28
Oct 22, 2015 08:21 AM
86CamaroDan
Sep 29, 2015 10:08 PM
