Green Foamy Slime in Differential OK ??
Old Aug 23, 2001 | 03:10 PM
GTA88's Avatar
Had the car up on the lift for inspection earlier today, where they failed me for a tiny hole in the last inch of the exhaust pipe, right before the muffler. Sooo, while it was up, I pried out the rubber stopper in the diff, and stuck in my little finger, and my finger came out with this foamy green stuff on it. Normal ? The result of some additive, maybe?
Water ?
88 GTA 5.7 TPI Charcoal Grey Bone Stock except for loose muffler which makes it a bit louder than normal.
Old Aug 23, 2001 | 03:29 PM
ATOMonkey's Avatar
Unless it's some kind of posi lube I wouldn't think that was anywhere close to normal. Normal gear lube is not green. It should never be foamy either. Especially after sitting for a while the oil should calm down. This is by far the weirdest thing I have ever heard.
Old Aug 23, 2001 | 04:20 PM
GTA88's Avatar
Terrific. Anyone else have any ideas ? Maybe the oil level is low and the gears are churning it into a foam ? But why a green foam ?
Old Aug 23, 2001 | 04:23 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Some grease is somewhat greenish looking. And it always ends up with a certain amount of foam in it; it gets whipped around in there pretty violently, and then it takes quite a while for all the air to rise to the top.
Still, if you don't like how it looks, just change it. If you haven't ever done that, then it needs it anyway, no matter what color it is.
ICON Motorsports
Old Aug 23, 2001 | 04:28 PM
poncho9789's Avatar
It sounds like there was some water leaking into the axle from the cover or the axle seals. That could produce the color that you described in your origional post if you have the axle torn down then you can take the axles out and replace the berrings.
97 formula w/6speed,cags skipshift eleminator, hurst billet pro shifter, 30#injectors,adjustiable fuel presure regulator,Moroso cold air induction,ported mass air sensor,accell300+ ignition box, accell 9000 wires, bosch platnum4 plugs,flomaster crossflow muffler,Lingenfiter 52mm throttle body,TPIS L98 SuperProfile cam,Crane 1:6 full roller rockers,Edelbrock subframe connectors,Edelbrock strut tower brace.
Other car is a 89 GTA w/700r4w/stage 2 shift kit, corvette servo, B&M mega shifter, TPIS bigmouth intake, TPIS large tube runners, TPIS 52mm throttle body,Edelbrock ported centerbolt heads,LT1 24# injectors,GMPP LT4 hotcam,CompCams Pro magnum roller rockers,Edelbrock headers, flowmaster crossflow muffler,MSD 6A, accell coil, bosch platnum plugs, this car is currently under rebuild and restoration.
Old Aug 24, 2001 | 08:44 AM
GTA88's Avatar
Well, I called up my local Pontiac dealer and he said yes, for my lsd the green color is normal since the fluid itslef, or the additive, can't remember which, is green. He said the foam is normal too, and that I should let it settle down a while before I check the level. SO rlb, you were right.
Old Aug 24, 2001 | 09:28 AM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
I just changed my diff fluid last month, and neither the diff fluid or the LSD fluid was green. Both were GM fluids.
The IROC Homepage
<A HREF="http://www.rit.edu/~jli4307/camaro" TARGET=_blank>
View the restoration of an 85 IROC</A>
Custom Thirdgen Subwoofer Enclosures
"I didn't know a bored out Ford could go so slow" -Shenandoah
dbrochard
Jan 28, 2016 08:42 AM
meeklay812
Oct 1, 2015 03:46 PM
usafirebird
Sep 29, 2015 11:58 PM
SS-EXPRESS
Sep 28, 2015 09:14 AM
dbrochard
Sep 19, 2015 08:13 PM
