Help me make max reliable HP!
Old Aug 24, 2001 | 04:28 PM
craiger's Avatar
Recently, I just did a compression check and found one cylinder reading a good 50 psi lower that the rest of the cylinders in my Z28. I put 5cc's of oil in the cylinder with a low reading and the psi increased from 120psi to 155psi, all other cylinders read 170psi. I'm not too excited to tell my wife the bad news But a man's gotta do what a man's gotta do! Now, I have a few questions for the rebuild. I plan to spend the money on eagle rods with hyperutecic pistions and balance the motor instead of putting a 383 in. I am wondering what will increase my horsepower best bang for the buck. I have a supercharger on the car running 8lbs of boost. I am contemplating putting a set of AFR's on the car and leaving the stock cam or porting a set of stock l98 heads and putting 1.6 exhaust valves in and a larger cam ( compucam 2032r). I have a good line on the afr's for about 1000 bucks. To get the heads and cam would cost me about 650. What should i do?
Old Aug 24, 2001 | 04:55 PM
Drakar's Avatar
Go with AFR's most people say they are better then ported stock. Just my .02
1989 Trans Am GTA, 5.7L TPI, TH700-R4, T-Tops, dual cats, 9-bolt rear, 3.27, Dynomax muffler, K&N
1992 Camaro RS, 5.0L TBI, T-5, T-Tops, 3.08, L69 Dual Snorkel, K&N - Sold
angel2794
Theoretical and Street Racing
25
Mar 7, 2026 01:08 PM
Frozer!!!
Jan 19, 2024 04:55 PM
InfinityShade
Aug 22, 2015 08:00 PM
ezobens
Aug 19, 2015 10:29 PM
firebirdchick28
Mid-West Region
Aug 16, 2015 02:52 PM
