Worn Cam Lobes?
Old May 25, 2005 | 02:08 AM
85cmroz28's Avatar
Car: 1985 Camaro Z/28
Engine: L69
Axle/Gears: One-Wheel-WOnder 3.08
Worn Cam Lobes?
I have been having a problem with my car making a popping sound when the engine turns around 4500 RPMs. I called up my mechanic and he said that it might be a worn lobe on the cam that isn't opening an exhaust valve all the way. He said 80s chevy engines are known to do this. Does this sound like it could be my problem?
Old May 25, 2005 | 05:13 AM
ede's Avatar
ede
might be, might not, you'd have to trouble shoot it a bit to know for sure
Old May 25, 2005 | 04:46 PM
85cmroz28's Avatar
Engine: L69
Any suggestions on how I can troubleshoot this problem?
Old May 25, 2005 | 05:51 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Take the valve covers off and make sure none of the rockers are loose. If any are, make sure the rocker studs aren't pulling out and the rocker nuts aren't backing off. If those are ok, pull the intake and take the lifters out and check them for wear.
Old May 28, 2005 | 10:47 PM
85cmroz28's Avatar
Engine: L69
Checked the rockers: they're all connected correctly. I fired the engine up with the valve covers off and the exhaust valve on the #3 cylinder is not opening as well as the other ones. I haven't had time to pull the intake off yet.
Old May 29, 2005 | 01:01 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
If you're lucky, it could just be a bad lifter. You'll have to take the intake off to find out either way.
J-money
Jan 4, 2019 09:45 AM
Jorlain
Oct 8, 2015 01:57 AM
tsfso59
Exterior Parts Wanted
Sep 9, 2015 09:09 AM
Stryker412
Sep 7, 2015 09:11 AM
Strick1
Sep 4, 2015 07:11 AM
