Messed up bleeding the brakes.
Old Aug 24, 2001 | 05:04 PM
Mike89GTA's Avatar
Damn, I was bleeding the brakes and I let the fluid resevoir get too low. Actually bone dry, there was nothing left all the way down to the caliper. Did I mess anything up inside the master cylinder or can I just fill it up and re-bleed?
Old Aug 24, 2001 | 05:47 PM
gmanuel's Avatar
you will need to bleed the master cylinder then the brake lines.
Old Aug 24, 2001 | 07:38 PM
SC88's Avatar
Car: 1988 Camaro SC
Engine: 355 Chevy
Transmission: 700
You may want to try to gravity bleed the system out first. Starting with the bleeder valve furthest from the master, fill your master and leave the cap off. Then go to the bleeder at the right rear and wait until fluid starts flowing. When and if it flows, close it and go to the left rear. Open that bleeder until it flows. Then the right front and then the left front. Don't step on the brake when trying to gravity bleed. If it doesn't bleed out then you probly need to bleed the master.
1988 Camaro Sport Coupe: Orignally: 305 TBI 700r4
Now: 1974 350CI, 2bolt,.030 over, Badger Flat Head Pistons w/ valve relief, Melling high performance street cam, GM Cast Vortec Heads, Edelbrock RPM Air Gap Intake, Edelbrock 600cfm w/ electric choke, GM HEI w/ vacuum advance, Weiand Low Profile Air Cleaner, Mallory 5 port Fuel Pressure Regulator, Mr. Gasket Throttle Cable Bracket, Corvette Shift Servo, 16" IROC Wheels, Every thing else is STOCK
Soon: 3.73 or 3.42, Gears, Hoosier Q/T
Old Aug 24, 2001 | 10:04 PM
Guest
Guest
Posts: n/a
Put fluid in there and run with it, just bleed it again... I have done that before and usually once its wet with fluid you can get the bubbles out fairly easily.
F-body-fan
Jan 12, 2023 01:49 PM
Ed1LE
Sep 30, 2018 09:14 AM
Bubbajones_ya
Oct 25, 2015 08:01 PM
mrbird
Oct 20, 2015 03:43 AM
