detonation help needed
Old May 25, 2005 | 11:34 PM
evoluzione1's Avatar
Car: 88IROC vert and a 83 w/evo body
Engine: 400 and 350
Transmission: T56 and 700R4
Axle/Gears: 323 and 373
Yes I done a seach.
I have a 92 z28 with the 305, ever since I got the car it had a little detonation knock under load ( realy bad when cold). I put in a lt1 cam and I still have the same knock? You would think after the cam swap that I would have done something to eliminate the knock, but nope. Everything else is stock and I have only done the free upgrades.
Old May 29, 2005 | 08:31 AM
Vader's Avatar
Detonation has many potential causes that wouldn't be affected by changing the cam. Combustion chamber deposits, lean mixture, overheating chambers, poor quench, excessive spark advance, low octane fuel, and lugging can all lead to detonation. Changing the cam may have little effect on some of those.
IROCZ1989
Jan 24, 2016 03:55 PM
kitt23
Exterior Parts Wanted
Aug 15, 2015 12:37 PM
Zachattack0925
Aug 12, 2015 09:52 PM
86camaroman201
Fabrication
Aug 11, 2015 10:39 PM
GEmrsn
Interior Parts Wanted
Aug 8, 2015 03:15 PM
