Special timing light for MSD?
Old Aug 25, 2001 | 01:40 PM
wickedfbody's Avatar
I have read somewhere that multiple spark discharge systems need a special timing light to accuratly check timing. I have since looked for such lights and have been unable to come across one. Do I really need a certain one? I am running the Accell 300+ which is multiple spark discharge and none of the literature it comes with says anything about a special light.
1991 Show Camaro in the works... to be back in from the painter in May or June.
  • Super Ram 383
  • 58mm TB
  • 30 lbs Bosch injectors
  • Fast Burn Heads
  • Jet Hot Coated SLP 1 3/4" Headers
  • Midrange cam
  • Custom Prom
  • Global West SFC's with custom reinforcements
  • 8 Point Custom Roll bar
  • ILE Brakes
  • Eibach Pro Kit springs
  • Polyuerethane Suspension bushings all around
  • ILE Aluminum Driveshaft
  • Full Autometer Instrumentation (10 guages)
  • Dupont custom pearl paint with flames and 6 ultra-thick clear coats
  • and the list goes on...
Old Aug 25, 2001 | 11:18 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
I use an inexpensive timing light and it works fine.
Old Aug 25, 2001 | 11:57 PM
Jza's Avatar
Jza
My inductive timing light doesn't like the multiple sparks. I have to bypass the box to set/check the timing. That's probably what you'll have to do.
Old Aug 26, 2001 | 01:04 AM
Omar's Avatar
My cheap light also works fine.
1989 IROC-Z 5.7L
NOS 5151 150HP kit
ProBuilt 700R4, PI Vigilante 2800 stall lockup
Baer Brakes 12" Sport System
Old Aug 26, 2001 | 07:26 AM
ede's Avatar
ede
my snap on light doesn't seem to work as well on msd ignition systems as my much cheaper one from sears.
ICON Motorsports
1st & 3rd
MM Black Diamond 538 F&AM
BRoss99
Aug 10, 2025 05:08 PM
Andrew6.688
Dec 13, 2015 10:59 AM
midias
Aug 15, 2015 05:07 PM
Omega
Aug 10, 2015 12:46 PM
Thirim
Aug 9, 2015 06:19 PM
