Heres What I Got with Desktop Dyno
Old May 28, 2005 | 02:19 PM
5.8L Camaro's Avatar
Car: 1988 Camaro
Engine: 350 V-Eight
415 HP@ 6000RPM = 405 TRQ@4500RPM
It holds steady over 400HP from 5500rpm to 6500rpm.
I put in the flow specs for Iron Eagle heads, 2.02/1.6, 9.5 comp.
Lingenfelter Hyd. FT cam, 212/224, .488/.496 with 1.6 roller tip rockers
Dual plane intake, 600cfm carb (Edelbrocks)
Small tube headers with mufflers
Since its a computer simulation, Id guess the actual might be around 25hp and torque less? Seem about right for those components? I'm also gonna be using a 100shot of nitrous.
Old May 28, 2005 | 07:13 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Actually since you have flow numbers, it should be pretty close. The more accurate information you can enter, the more accurate the results are.
Oh course real world is always different. Putting an engine on a dyno is only good for tuning. What it actually does on the street or strip once it's in a car isn't usually what you expect.
Old May 28, 2005 | 11:07 PM
Damon's Avatar
Not sure what specs you plugged in but I got just over 350HP attempting to duplicate your simulation.
I assumed a 355ci engine and used the Chevy Hi Performance head flow test numbers for the Iron Eagles. The cam I did per the specs you listed and assumed a 110* LSA on a 106* ICL.
That's an awful small cam to be getting well over 1 HP/ci with.
Old May 28, 2005 | 11:43 PM
Car: 1988 Camaro
Engine: 350 V-Eight
I might go with a bigger cam. I want to make the most power with out having to rev past 6000rpm though
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
darwinprice
17
Oct 11, 2015 11:51 PM
Nervous2
Oct 8, 2015 10:53 PM
LT1Formula
Oct 8, 2015 08:34 PM
