I need cylinder head info
Old May 28, 2005 | 04:10 PM
SC88's Avatar
Car: 1988 Camaro SC
Engine: 355 Chevy
Transmission: 700
I am putting heads from a 305 TBI onto a 350 TBI. What issues will I run into. I know the diffrences in the heads (valves, chamber cc's). Will there be a computer issue?
Old May 28, 2005 | 04:21 PM
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
Probably won't have any computer issues. But you might get some knock counts if you don't run a higher octane gas.
Old May 28, 2005 | 09:54 PM
izcain's Avatar
Car: 1983 Camaro Z28
Engine: 584
Transmission: TSI Glide
Axle/Gears: Quick performance 9 inch
I helped a guy install a 355 with a built bottom end with a set of 305 torquer heads that were from my 305 experiment for power (ran good but not enough).
It took his mild compression of like 9:2;1 and bumped it to right about 10:1 is the motor stock that your putting the 305 heads on? if it has flatop or pop up piston in it your compression is going to be really high. should give it some good thump :-)
Old May 30, 2005 | 01:30 PM
SC88's Avatar
Car: 1988 Camaro SC
Engine: 355 Chevy
Transmission: 700
Everything is stock. I was doing a head gasket job for my cousin and I noticed a crack in the rear combustion chamber starting from the seat of the intake valve. To save him some money I offered my original 305 heads. So to answer your question, no flat tops, the pistons are original, with the valve reliefs.
Old May 30, 2005 | 02:55 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Flat-tops have valve reliefs but no dish. LO5 typically had slightly dished pistons with valve reliefs. Fully dished pistons don't require valve reliefs.
A thick head gasket will help relieve some of the compression.
You'll also be reducing the size of the intake valves from 1.94" to 1.84".
Old May 30, 2005 | 03:28 PM
izcain's Avatar
Engine: 584
the intakes are 1.81 or so on the intakes of the z28 heads but on all other stock 305 they have like 1.78 valves or at least close to that I remember that the z28 heads had larger valves I thought
Chuck84TA
Jul 15, 2016 09:05 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
NinjaNife
Aug 23, 2015 11:49 AM
db057
Aug 22, 2015 08:17 PM
89mulletbird
Southern California Area
Aug 10, 2015 10:16 AM
