Where does this accessory bracket go???
Car: trans-am
Engine: tpi
this is a 86 tpi ta. I am putting the ac and ps on and have this bracket that does not seem to go anywhere. Is this even off my car???
I have a parts bin that I took bolts and brackets out of and this could have gotten mixed in with my cars parts in the confusion.
Where does this go???
Car: clapped out 84Z
Engine: 355 efi roller
Transmission: tremec TKO
Bracket is upside down. Flip it over left to right. Two holes on the right as looking at the engine by leaning over bumper go to the water pump. Upper hole on left is for the bolt that goes through the alternator and into the pass cyl head. Just looked at my car, assuming you have V-belts. I think the ground from the battery goes to the threaded hole.
