Lt4 Hot Cam Setup
Old May 28, 2005 | 09:39 PM
IROCZ28CHAPMAN's Avatar
Car: 1988 camaro
Engine: 350 lt4 hot cam stock head 10;1 compression with an edelbrock carb 1406 and performer style intake having problems on the track
Transmission: t-5
Lt4 Hot Cam Setup
I have an 88-92 style block, with an lt4 hot cam, performer style intake with a 1406 edelbrock carb. The heads are stock but had a valve job done. I'm running 1.6 roller rockers. I have t-5 tranny with the stock rearend the rear end is whatever came with the 2.8 v6 camaros. My car is strong off the track but im having problems on the tracknot sure if it is my rearend or something else. im in the process of converting to fuel inj (holly stealth ram) with the speed density computer and i think that will help but i can't keep traction on the track not sure what i should do to help solve my problem. I want to switch to a 4th gen rear end but not sure if i shouldd go with 3.42 gears or 3.73. how does my setup sound and what does it sound like i need to change. These are my times from my last run:
60 ft- 2.4
r/t- 1.2
1/8-9.8
mph-73
1/4-15.1
mph-93
Old May 28, 2005 | 10:05 PM
AJ_92RS's Avatar
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
Try translating your post to grammatically correct English and you'll probably get a response.
And turn off your "Caps Lock" key.
krisner89
Oct 10, 2015 06:03 AM
beastin91rs
Oct 9, 2015 07:38 AM
80s Poncho
Aug 19, 2015 06:45 PM
1988iroc350tpi
Aug 14, 2015 07:52 PM
anesthes
Aug 8, 2015 09:37 PM
