Tune up
Car: 89 Iroc
Engine: 305TPI
If you want just go get any stock replacement wires and AC Delco plugs other wise you can get bigger wires and different plugs. I have Accel 8.8 race wires on my car and I have heard good things about AC Delco Rapid fire plugs (I have stock replacement plugs) You can replace the coil with a MSD Blaster Coil or Accel Super Coil if you want to not the typical thing to do on a tune up. An Accel Cap and Rotor would be a good thing. The PCV valve may or may not be a good replacement. Also you could do the fuel filter while you are at it. I think that is about all that I can think of and depending on where you buy this stuff and what you buy it may cost you about $100 or more to do it all.
