fuel problem need help
Old May 30, 2005 | 08:17 PM
bmf89irocz's Avatar
Hi, I own an 89 Iroc Z with a 305 TBI motor. The problem all started when I replaced the fuel pump. I did it once, and the pump didnt work. I have done it a second time, tested the pump and it worked, then put it all back together. I had to hold the two connectors together for it to work, the pig tail off of the pump to the connector that gives it power. Now even when I hold them together, i dont hear the pump working. I dont know if its an electrical short or something else. Any suggestions or ideas would be greatly appreciated. I need to get my daily drive running again. Thanks for reading.
Josh
Old May 30, 2005 | 09:00 PM
Token's Avatar
Car: 1992 Firebird
Engine: forged 357
Transmission: 700r4, 2200-2400 stall, vette servo
Axle/Gears: stock pegleg 2.73 drum (temp)
see if this thread helps any
Glowsock
Jul 24, 2025 03:15 PM
Ghettobird52
Jul 5, 2024 11:18 PM
92camaroJoe
Jul 29, 2023 07:57 PM
Infested
May 22, 2018 11:56 PM
92camaroJoe
Aug 13, 2015 06:07 AM
