cant move dipstick
Old Aug 28, 2001 | 12:11 PM
92RS shearn's Avatar
Car: 92' RS
Engine: LO3
Transmission: Probuilt 700R4
Axle/Gears: 3.70 9-bolt
cant move dipstick
I did a header install a couple weeks ago and in order to get them in I had to bend the dipstick over a bit, but now it is very difficault to pull out and I am sure impossible to get back in, cant tell if I bent it or what, this happen to anyone else? and what keeps this thing in incase I have to change it?
1 5/8 Hooker Competetion Headers, custom y-pipe,no cat, modified Flowmaster,Edelbrock open filliment filter with K&N filter in it
160 stat, BF G-Force w-rated tires, Hurst dual gate shifter
Old Aug 28, 2001 | 02:53 PM
rezinn's Avatar
Nothing keeps it in, it just slides in and out. There should be one bolt attaching the dipstick tube to the block or the head, though. You may have bent it too much, try to bend it back somehow.
Old Aug 28, 2001 | 03:10 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
What you probably did is bend the tube in the plane 90° from the one that the bends are in it now. So, now the dipstick not only has to bend in its normal way, but also across its face. It's pretty strong that way, it's about similar to trying to bend 3/16" plate steel.
The only solutions are to bend it back, or replace it.
ICON Motorsports
Ed1LE
Sep 30, 2018 09:14 AM
NZKnight
Oct 15, 2015 02:47 PM
BrianChevy
Wheels and Tires
Oct 13, 2015 12:33 PM
gord327
Oct 3, 2015 01:25 PM
Fanatic1074
Oct 2, 2015 03:47 PM
