help wit oil cooler
Old May 31, 2005 | 07:15 PM
kowboy59's Avatar
Car: 88 iroc-z z-28
Engine: 383
Transmission: th400
help wit oil cooler
ok so i took out the oil adapter because there was a leek. well now it isnt flush with the if i want the oil filter on. if the top of the cooler is flush, then there isnt enough thread for the oilf filter. i thynk i needed a spacer or sumtin. well there is a o-ring on the top and im hopin thats it, but i want to make sure everythyng is right so if anybody has the off the wall pictures i would appreciate this. i am also goin to do it by myself becuz someone helped me the first tyme and he was all wrong in wat he thought and i was right. soo..... ur guys help is appreciated.
Old Mar 8, 2007 | 04:50 PM
cammed91's Avatar
Car: 1991 Pontiac Trans Am
Engine: 350 HSR, Cam, ignition, headers
sorry to bring up such an old thread but i found this and this is almost exactly what im having problems with. the oil filter adapter bolts are sitting too high and when i go to put on the oil cooler adapter it wont sit low enough for it to seal correctly. any help would be appreciated.
thanks
Old Mar 9, 2007 | 09:27 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
Lucky you my engine's torn apart
Maybe I haven't had enough coffee yet but which part is causing you problems?
Attached Thumbnails help wit oil cooler-p3090003.jpg   help wit oil cooler-p3090004.jpg   help wit oil cooler-p3090005.jpg
Hotrodboba400
Dec 10, 2019 07:07 PM
92projectcamaro
Jan 18, 2016 08:00 AM
tyeo098
Nov 30, 2015 06:27 PM
CatmanFS
Sep 19, 2015 09:00 AM
apie2546
Sep 5, 2015 07:40 PM
