vibes @ 45mph....driveshaft?
Old Aug 28, 2001 | 12:31 PM
85transamtpi's Avatar
Ive been feeling a slight shake that happens only at around 45mph. If I put it in neutral or 3rd it still vibes until I slow down or speed up some. Is this the driveshaft? Is this a suspension problem? As far as I know everything under the car is original. The shocks/struts still feel pretty firm but may need replacing.
85 trans am
LB9
th700r4
3.27 bw rear
"performance suspension"-i dont know if that matters
thanks
Old Aug 28, 2001 | 03:03 PM
Kat's Avatar
Kat
Car: Camaro Vert
Engine: 355 HSR
Transmission: A4
Axle/Gears: 3.73 S60
Usually between 45mph - ~60mph it is yer wheels are outta ballance.
More than likely that is yer problem.
Kat
Old Aug 28, 2001 | 04:15 PM
They were supposedly "expertly" balanced at Firestone. I'll take it somewhere else and see if that helps. Ive had MANY problems with Firestone service and all I've had done there is get tires mounted! I guess I like their tires, but hate their service.
thanks for the advice
Old Aug 29, 2001 | 12:41 AM
Sitting Bull's Avatar
Car: 1986 Sport Coupé
Engine: 305-4v
Transmission: 700R4 and TransGo2
Might be the universal joints on the drive shaft.
Old Aug 29, 2001 | 01:11 AM
Ovrclck350's Avatar
If you put it in neutral, and it was still vibrating, then it shouldn't be your driveshaft.
86Chicken
Nov 8, 2001 11:19 AM
86Chicken
Aug 21, 2001 02:41 PM
JDMZ28
Car Audio
May 15, 2001 02:59 AM
JDMZ28
Car Audio
Jan 9, 2001 03:56 PM
JDMZ28
Car Audio
Jan 1, 2001 03:44 AM
