adjusting rocker arm bolts.
Old Aug 27, 2001 | 12:35 PM
sunbound's Avatar
Car: 1987 IROC-Z
well, my engine is in, and i want to double check the rockers to make sure they are adjusted properly... i had to take the heads off to get a bolt out, and i had to take out the push rods, etc....
so, how do i check them for proper tightness?
the engine is a 350 tpi out of an 89 iroc.
thank you
jon
Old Aug 27, 2001 | 07:55 PM
ede's Avatar
ede
you have studs with nuts not bolts. rremove valve covers with engien running loosen rocker nut untill you hear it ticking then tighten it untill it stops then go another 1/2 to 3/4 turn. repete till you have all 16 rockers checked and adjusted.
ICON Motorsports
1st & 3rd
MM Black Diamond 538 F&AM
Old Aug 28, 2001 | 07:36 AM
sunbound's Avatar
Car: 1987 IROC-Z
sounds simple enough, thanx.... im never gonna buy a hayes manual again... doesnt tell me enough, just (instalation is the same, in revers order) no details on adjustments....
jon
Old Aug 28, 2001 | 08:52 PM
89project's Avatar
Is it bad for the engine to be run with no cover on it? What about MESS.
Does it get messy adjusting the rockers with the cover off?
Just curious, I am looking to adjust soon. Just wanted as many details as possible.
Old Aug 28, 2001 | 08:59 PM
Vader's Avatar
89,
It can get messy, but it is the most accurate way to set lash. The engine is supposed to be at full operating temperature to set valve lash, regardless of the cam/lifter design. There are oil deflector clips available to keep the oil mess to a minimum. and I've had pretty good success with them. Setting the lash cold can get you very close, and typically there is enough travel in hydraulic lifters to compensate for innaccuracies of this method, but it is more accurate and just about as easy to adjust them while idling.
It's also a good excuse to do a thorough engine cleaning after you've finished.
Later,
Vader
"Get UP - Drop the bombshell!"
Adobe Acrobat Reader
Old Aug 29, 2001 | 07:58 AM
sunbound's Avatar
Car: 1987 IROC-Z
how much and where did you get the deflector clips?
[This message has been edited by sunbound (edited August 29, 2001).]
Old Aug 29, 2001 | 09:28 AM
88305tpiT/A's Avatar
Car: 2016 Ram 1500
Engine: 3.0L Diesel
Transmission: 8sp
they are like 7 bucks for 16 from any BIG parts supplier/store
Hotrodboba400
Dec 10, 2019 07:07 PM
J-money
Jan 4, 2019 09:45 AM
New2Chevy
Sep 28, 2015 12:35 AM
ericjon262
Sep 11, 2015 06:07 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
