Starter heat soak.
Old Aug 29, 2001 | 10:35 AM
FlyinLow89's Avatar
Car: 1995 Formula/2001 GTP
Engine: 5.7 LT1/3.8 Supercharged
Starter heat soak.
I have problems starting my car when its been driven for a little while and its worse on hot days. I'm aware that this is dew to my larger headers overheating the starter. I bought a Moroso heat shield which is just an aluminum cover. I was wondering if anyone has tried one and how they work. I'm also going to through a high torque starter on just to be safe.
Old Aug 29, 2001 | 11:45 AM
Craig84Z's Avatar
Car: 1984 Camaro Z28
Engine: Blueprint 383
This might sound silly - but check both of your battery cables and make sure they're not corroded. I had just put on headers and kept thinking it was heat soak. I replaced my positive cable and voila.
Craig
84 Z28 305HO, 5spd, 222,000 miles, Edelbrock intake, Hedman headers, low restriction exh(w/cat), K&N air filter, 14.630 at 93.17mph
Del-A-lum front control arm bushings, Moog ball-joints, Energy suspension front sway bar end links, Moog rear sway bar end links, Eibach pro-kit springs, tokico shocks/struts, AU secondary rods
www.indycamaro.com
Old Aug 29, 2001 | 05:31 PM
Z28DJP1987's Avatar
Went through the same problem with heat soak
after header install, went with a mini high torque starter and that was the solution.
Everything worked find after that even in the hottest weather.
Old Aug 29, 2001 | 05:50 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
I had an even worse problem than heat soak.... in the form of a 10½:1 400.... I also did the mini-starter thing. It is so completely different than the stock garbage, I kick myself every time I think about all the years I struggled with the little weenie stock crap, while I could have fixed it so easily for $150 and a half-hour of work. It spins the motor better than the best that the stock one ever did, about twice as fast even as a brand new stock one could spin a room-temperature 305.
ICON Motorsports
3rd gen money
Oct 11, 2019 09:57 PM
sheachopper
Jul 31, 2019 11:27 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
SS-EXPRESS
Sep 28, 2015 09:14 AM
