Nicked the crankshaft
Old Jun 2, 2005 | 09:31 PM
m3thod's Avatar
i nicked one of the crankshafts journals just a tad, clearance is all good and everthing. how bad will i damage the rod bearing, should i have to get it regrounded? or should i just put it in?
Old Jun 2, 2005 | 10:35 PM
SLEEPER 86's Avatar
Car: 86 coupe
Engine: 383
Axle/Gears: 9 bolt 3.27 posi
i have seen cranks polished out with crocus cloth
Eric B
Old Jun 3, 2005 | 06:22 AM
ede's Avatar
ede
i'd take it to someone to be polished. i polish all my own cranks but wouldn't mess with one that's been nicked. did you do it installing rods/pistons? you there are ways to be 100% sure it'll never happen when you install the rods and pistons?
Old Jun 3, 2005 | 03:23 PM
DartByU's Avatar
Car: 92 Camaro RS
Engine: 305 TBI
Carefully file down the high spots of the nick and then lightly polish it smooth and it will be fine, unless the nick is a huge one that covers the width of the bearing. If this is a very high HP engine where even a tiny scratch could lead to a crank failure then you might want to have it reground.
Old Jun 3, 2005 | 03:39 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Get yourself some pieces of rubber or plastic tubing, and slip them over the rod bolts next time, to avoid this.
db057
Apr 28, 2019 07:45 AM
Eric-86sc
Feb 25, 2016 09:02 PM
bigjay89gta
Oct 15, 2015 08:04 AM
Nick McCardle
Sep 10, 2015 08:36 PM
