WHATS HAPPING!
Old Aug 29, 2001 | 05:56 PM
SpeedStar's Avatar
WHATS HAPPING!
I got a code 21 the other day(tps voltage high) and after that happened my car has been running like crap. Its a 91 Z-28 305 TPI. If I start it in the morning its fine, but when I leave work and go to lunch it idles bad and sometimes dies. When I Start it to leave work everything seems fine for the rest of the day. Could it be my tps is bad. Any suggestions would be great.
1991 Camaro Z-28 305ci 230hp
1985 Camaro Coupe 331ci 300hp
http://www.geocities.com/speedstar38...Speedstar.html
Old Aug 29, 2001 | 06:23 PM
89 Iroc Z's Avatar
Car: 1989 Iroc-Z
Engine: 350, ZZ4 equivalent
Transmission: Pro-Built Road Race 700R4
Axle/Gears: 3.23 Dana 44
A code 21 means your throttle position sensor is reading to high voltage. You need to recalibrate your TPS sensor if that doesn't fix it you will need to buy a new one.
1989 Iroc-Z Blue T-Tops
Lightly Moded:
Headers, Rebuilt B&M 700R-4 tranny, Airfoil, K&N's
LKASurfing
Feb 22, 2015 03:12 PM
TPI_BLAZER
Jan 9, 2013 12:24 PM
fasteddi
Sep 16, 2012 03:00 PM
BMmonteSS
Brakes
Aug 19, 2005 06:53 AM
