How can I make my speedometer right??
Old Aug 27, 2001 | 07:59 PM
CamaroX84's Avatar
I am putting in a 3.42 rear end in my car. I currently have a 3.08. Do I need to replace both the plastic gear and the metal one on the output shaft of the trans? Or just the plastic one? Any help would be appreciated. Thanks.
Old Aug 27, 2001 | 08:39 PM
91B2L's Avatar
Car: 1991 Z-28
Transmission: TH700
I had a shop correct it for $37 when I switched gears,sorry no help.
Old Aug 28, 2001 | 02:59 PM
CamaroX84's Avatar
Anyone else? Thanks.
Old Aug 28, 2001 | 06:21 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Both gears are plastic. You'll probably be able to just change the driven gear.
Old Aug 30, 2001 | 12:29 AM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Automatic or manual? what tire size? We need that info to tell you what speedo gears you need.
1991 Camaro Z28
5.7L 5-Speed (originally 305)
317 RWHP, 418 RWTQ
13.23 @ 107.62 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Member: SoCal F-Bodies
-=ICON Motorsports=-
Old Aug 30, 2001 | 06:08 AM
Pat Hall's Avatar
I changed from 2.73 to 3.42 in my car, and I had to change both the gears. It's not too hard to do yourself if you want to save a few bucks. I can't remember for sure what ratio size the cutoff is, but there's two different gears for the transmission output shaft. I had the red one for the 2.73 ratio, and had to switch to the gray one for 3.42. The speedometer gear article in the tech section of this site should have the gears listed that you need. I went to the Chevy dealer and they were able to look up the proper gears I needed on their computer. They had a chart on there with the proper combos. Oh yeah, I also had to get a different size sleeve for the cable gear as well. As long as you talk to a knowledgeable parts guy at the dealership, they should be able to hook you up with what you need.
89RS w/350 TPI; 69RS/SS w/450 HP 350/Muncie 4-Speed "Too weird to live, too rare to die."
Frozer!!!
Jan 19, 2024 04:55 PM
Scorched1984
Wheels and Tires
66
Apr 16, 2016 06:56 PM
AUZ28
Oct 12, 2015 08:40 AM
AUZ28
Aug 26, 2015 06:08 PM
AUZ28
Interior Parts Wanted
Aug 25, 2015 07:29 AM
