20+ Degrees BTDC
Old Aug 29, 2001 | 08:16 PM
breathment's Avatar
20+ Degrees BTDC
ok i checked my timming today after figuring out i could EASILY read the marks after cleaning off the tab. and anyways after i jumped the Diag. terminals i was getting about 20* BTDC, now the car wasn't fully warmed up, but i thought if u jumped the A & B terminals then it wouldn't matter, and when i took out the paper clip i was getting about 14* BTDC. should i wait for the car to be FULLY warmed up, or is there a chance its really that far advanced, im not having any pinging or anything.
88' GTA 350 MODS---> air foil, K&N, Shift Kit, 180* therm, TB bypass, Gutted CAT
Old Aug 29, 2001 | 10:27 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
I've never checked the timing by jumping A and B...only by disconnecting the EST Bypass connector.
Old Aug 30, 2001 | 03:20 PM
Damon's Avatar
Can't be. If you jumped the proper terminals then it would drop you down to the base timing. Anything that the computer puts in is ADDITIVE to that. It can't subtract from the base timing. Check which terminals you are jumping again (it's not always a & B) or just disconnect the timing wire.
Old Aug 30, 2001 | 04:19 PM
breathment's Avatar
wut\where is the EST bypass connector?
Bubbajones_ya
Jul 6, 2024 08:32 PM
RedLeader289
May 28, 2019 01:47 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
ironbmt
Sep 27, 2015 06:00 AM
