Quick: How to remove the rear rotor
Old Aug 31, 2001 | 11:00 AM
ArnoldBraker's Avatar
I my brakes. The front went fine but I can't figure out how to remove the rear rotor. Also, I need a special tool to get those bearings out to grease them, right? Thanks. ~Arnold
Old Aug 31, 2001 | 11:07 AM
iroc5speed's Avatar
if I were you I'd just buy new bearings for the new rotors. the rotors should just slide right off,though I myself have never done the rear ones. I don't think you would need a special tool
'86 IROC 5-speed
305 LG4
edelbrock performer rpm intake
edelbrock 600 cfm carb
msd pro billet hei distributer
'95 3.23 rearend
hotchkis rear suspension
PST front polygraphite suspension
Old Aug 31, 2001 | 02:18 PM
Guest
Guest
Posts: n/a
The bearings themselves in the front you dont need any special tool to get them out, the front will come out as soon as you take the rotor off, the rear you have to remove the seal (which will ruin it) and then its out too.
The rear rotor *should* just pull off the axle once you have the caliper off. If it doesnt, chances are its rusted on there and will take some penetrant, some praying, and some luck to get it off.
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
Eric-86sc
Apr 3, 2016 03:52 PM
3rdgenparts
Aug 8, 2015 07:09 PM
