White smoke
From: In my own little world - but they know me well in here
Car: 88 Sport convertible
Engine: 305TBI
Transmission: AUTO
Axle/Gears: 3.42 rear end
White smoke
When I start my car after sitting all night, I get a puff of white smoke from the exhaust...well really a small cloud...
Seems like it is getting worse over time. Anyone have an idea what it might be?
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
It is time to change the valve stem seals. It is a pain but the only way to correct your start up consumption problem.
Engine: 305TBI
Transmission: AUTO
and where are the valve stem seals? what has to come off to replace them?
Car: 87 Z28
Engine: uh does the name give u a hint
buddy i used to have same prob when i bought mine its probly the headgaskets cause white smoke eguals water, black means your running rich, and a greyish blue smoke means oil.
Engine: 305TBI
Transmission: AUTO
Understand....BUT had too many people (outside this board tell me same thing....valve stem guides)
only happens on startup.....no smoke of any color/kind after that
Car: 86 Firebird, 2002 Monte Carlo, 91 v
only way it's the head gaskets is if it's seeping coolant in while the car sits and it's a slow leak. my jimmy would fog the neighborhood. Valve seals are a pain. I never did it with the heads on the motor I can imagine it's a nightmare. The valve covers have to come off and you have to compress the valve springs. You'll need compressed air to hold the valves up to prevent them from falling into the cylinder
Car: 1988 Pontiac Firebird Formula
Engine: 5.7 TPI
Actually, valve stem seals are not that bad. Just time-consuming. I went slow, and it took about 3 hours for the job. No more smoke at start-up, and as an added bonus, my 190K mile motor, does not use any oil between changes.
Car: Tree Huggers
Engine: Do Not
Transmission: Appreciate Me.
Have someone start it for you, smell the smoke. That will tell you... (and if's it's oil burning, you may want to get your eyes examined.. if you aren't young anyway).
Engine: 305TBI
Transmission: AUTO
Don't need anyone to tell me it DOES smells like oil......
And thanks for the suggestion for an eye exam....
BUT I get one every year and can see better than a lot of "younger folks"
Car: 84 & 92 Z28s
Engine: 305 carb & 305 TPI
As others have said, white=water and gray=oil. However, a small wisp of oil smoke can apear to be white-ish. Oil smoke tends to linger a bit while white smoke from water (steam) will dissipate quickly.
If you are absolutely sure it is oil smoke and any external sources of oil (stuck open pcv, etc..) have been eliminated, stem seals are the most likely culprit
-B
-B
Pac J
May 17, 2020 10:44 AM
