Primeing the engine
Old Jun 6, 2005 | 08:14 PM
rsc350's Avatar
Car: 92 Camaro RS
Axle/Gears: 3.73 Truetrac
Primeing the engine
So I searched around on the bord for stuff like this... I dont know whats going on, I'm building my engine, got it all togather and looks good too. I broke my electric drill the other day so all I got is a cordless drill, SO I threw the cordless drill on it just for giggles and it seems the oil pump aint even grabbing any oil... now correct me if I am wrong, even though it is a cordless drill spinning much less rpm wise than the electric drill it should sling around oil? Or do I just need a bigger drill? the cordless did not even put oil in the filter nor did it pump anything out of the sending unit hole when I took that out... Is my oil pump bad?
Old Jun 7, 2005 | 05:08 AM
ede's Avatar
ede
don't worry about it. priming a SBC is a feel good thing for people with no knowledge or confidence in their work. most likely if you have the correct tool your drill doesn't have enough *** to spin the pump
Old Jun 7, 2005 | 06:08 AM
DENN_SHAH's Avatar
Car: 83 POS monte carlo 2015 chevy P/U
Engine: 92 5.7 tpi 5.3
Transmission: 700r4 6L60E
Axle/Gears: 2.42 too high
im on the other side from ede, i am a firm believer in priming, i have plenty of knowledge & confidence in what i know & what i can do. i prime motors not so much to pre-oil, (but it is how i was taught & i also don't pre-soak the lifters), but to check for leaks.
by priming i have caught on the stand, a block that had a hair line crack at 1 of the passage plugs on the back of the block, another block that had a crack at the passage plug near the filter, & a defective oil passage plug on the back of the motor. how many passage plugs have you heard of that had a pin hole in them? im at 1 so far.
once the motor is in the car,.. not much reason to prime it, once its running & if it has a leak, you have to find & fix it.
either your drill is too weak,.. or you had it running in the wrong direction.
Old Jun 7, 2005 | 07:54 AM
406TPI's Avatar
Car: 1985 IROC-Z
Engine: Magnacharged LS1
Axle/Gears: Ford 9" 4:11's
I ALWAYS prime a new motor just to find leaks. Skipping this step could just mean more work for you in the future. I learned this valuable lesson long ago when I primed a motor I built on the engine stand and had 60psi of oil shoot half way across my garage because of a plug I had missed.
If you are spinning the pump the right way and not circulating oil, you have problems. Even a wussie drill will spin an oil pump enough to move oil for a short while before it burns up.
Old Jun 7, 2005 | 08:29 AM
CAH383's Avatar
Car: 86 Camaro Z28
Engine: 5.3 LM7
Transmission: TH400
I burnt up what I thought was a decent drill on a new pump. Beg, borrow, steal a different drill, just prime it first.
Old Jun 22, 2005 | 10:47 AM
rsc350's Avatar
Car: 92 Camaro RS
Well guys, the electric just did not have enought **** behind it to get oil up there for the first time. I threw a 3/4 hp drill on it and spun it till the drill started smokeing, good thing it aint mine . Now that the oil pump has oil in it the battery drill will throw some oil around, for a second anyways... so note to self 700 rpm drill not enough, 2,900 rpm drill much better.
Glowsock
Jul 24, 2025 03:15 PM
Frozer!!!
Jan 19, 2024 04:55 PM
Cameeeero
Aug 20, 2015 03:06 AM
ElPaleterro85
Aug 13, 2015 03:49 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
