how to set timing after change to carb
Old Sep 1, 2001 | 09:33 AM
speedlvr's Avatar
With TBI, you dicsonnect the electronic vacuum advance and hook the timing light to the number one plug wire using an inductive pick up. How does setting the timming differ without the computer?
Old Sep 1, 2001 | 11:07 AM
Guest
Guest
Posts: n/a
I never thought I'd see this... boy do I feel old.
Anyways, to answer your question, if there is a vacuum advance on the distributor you have (MSD pro billet eh?) then you have to disconnect and plug that before you set your base timing. Thats the only difference.
Old Sep 1, 2001 | 07:39 PM
speedlvr's Avatar
That easy, huh? Thanks oldtimer.
Frozer!!!
Jan 19, 2024 04:55 PM
specialized
Jun 18, 2022 09:26 AM
customblackbird
Aug 15, 2021 10:16 PM
midge54
Dec 27, 2019 04:14 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
