Remove air pump=Oil leak
Old Jun 9, 2005 | 09:38 PM
85z28guy's Avatar
Car: 85' Z28
Engine: 383 roller
Axle/Gears: Ford 9" 3.70
I have developed an oil leak, and want to start with easy things first then go to the more involved things. The only thing I have done this year was remove the air pump. I don't think I put bolts back in the accessory holes. Could this cause my leak?
Old Jun 9, 2005 | 09:54 PM
Benm109's Avatar
Car: 1991 Chevy Camaro
Engine: 305 TBI
No, not putting the bolts back in should not cause any kind of leak.
Old Jun 9, 2005 | 10:00 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
You might want to have a look at the other end of some of those holes. There's a hole in the front of the block going right through to the crankcase that likes to leak oil if it's not plugged.
Old Jun 10, 2005 | 06:15 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
The upper bolt hole on the pass side of the block that's used for the smog pump bracket, on the front beside the water pump down low, goes RIGHT DIRECTLY INTO the crankcase. In fact if it had a mechanical (carb) fuel pump, that bolt has to be real short, or it will hit the fuel pump rod and keep that from working.
If that one is not there, you will most definitely have an oil leak.
Put a short bolt in it, with a little silcone on the threads.
Old Jun 10, 2005 | 10:53 AM
85z28guy's Avatar
Car: 85' Z28
Engine: 383 roller
Thanks a lot. Thats probably exactly what it is.
backtothe80s
Sep 5, 2015 12:39 AM
mcquigg
Aug 13, 2015 02:26 PM
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
drathaar907
Aug 6, 2015 04:20 PM
