are all gm CODES the same in 1990?
Old Sep 3, 2001 | 06:15 PM
jasons86iroc's Avatar
i have a 1990 grand am, and i read the codes and it gave me 3 flashes pause 5 flashes. does anyone know what this is?
Old Sep 3, 2001 | 07:35 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
There's a list of the codes in the FAQ section of this website. Three flashes and five flashes is a code 35.
1991 Camaro Z28
5.7L 5-Speed (originally 305)
317 RWHP, 418 RWTQ
13.23 @ 107.62 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Member: SoCal F-Bodies
-=ICON Motorsports=-
Old Sep 3, 2001 | 08:38 PM
jase's Avatar
that code 35 is for the IAC.It needs to be replaced.Its a idel speed error, unless you have a2.2l engine.
Old Sep 3, 2001 | 08:48 PM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
I don't know off hand what a code 35 is (OBDI is way too old) but if it is the IAC, that doesn't mean its bad. Could be a wiring problem, or something like a vacuum leak. If there is a vacuum leak, the computer will drive the IAC all the way closed trying to lower idle and if it forces it all the way shut and still can't control the idle, it condems it. Not saying that the IAC isn't bad, but its just one of the many possibilities.
What engine do you have?
FREE CARFAX Record Check
If you live in Southeastern US, check us out!
South East Thirdgen
GM Master Tech
ASE Master Tech + L1
Savannah, GA
'87 Trans Am
S/D TPI retrofit including functional PassKey,
22# injectors,
Whatever chip I feel like burning,
JET AFPR, Ported Plenum,
TB Coolant Bypass, Custom Cold Air,
SSM SFC, KYB Shocks, Boxed LCAs, Wonder Bar,
8mm Accel wires,
Flowmaster Exhaust,
16" GTA rims,
Corvette Servo,
3.73 Posi
4wheel Disc Brakes
Summit 1-5/8" headers, 2.5" Dynomax catback.
Best 1/8: 9.519@72.74
'97 Bonneville SSE
Falcon50
Aug 22, 2020 03:26 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
HoosierinWA
Oct 7, 2015 10:15 AM
racereese
Oct 3, 2015 03:46 PM
bjpotter
Oct 2, 2015 09:12 AM
