Can't start
Old Sep 3, 2001 | 04:38 PM
CaMaRo_Berlinetta's Avatar
Can't start
I got a friend and he got a 350 carb with mild cam .... it doesnt start what could he check exept for timing
gas goes in the motor thers a spark it turns but it doesnt light up
an other problem is he had prestone in is oil and it look like it was comming from the first driver side piston
if u got advise go a head i need help
Old Sep 3, 2001 | 09:03 PM
could it something else then just the timing and fireing , sparks
plus every thing is knew except for the block and heads but they are rebuilt so
My web Site
Old Sep 3, 2001 | 10:52 PM
mystikkal_69's Avatar
Car: 1988 IROC-Z
Engine: L98 (350 TPI)
Transmission: MD8 (700 R4) + 3.42 LS1 Rear
well if you have spark and fuel assuming the spark plug wires are in the correct order try this. while someone is cranking the engine, you or someone should try to move the distributor counter clockwise and clockwise. See which way you turn the dist that makes the engine wanna start. i had to do that with my 355 to get it to start.
88' IROC-Z, 350 TPI, 700-R4
Orr89RocZ
Apr 25, 2016 08:28 AM
Wade787b
Sep 29, 2015 01:15 PM
SolarGoldRaptor
Carburetors
16
Aug 25, 2015 02:25 PM
92camaroJoe
Aug 13, 2015 06:07 AM
86Base
Aug 8, 2015 01:34 PM
