Coolant in oil
Old Jun 10, 2005 | 06:35 PM
ajbutowicz's Avatar
Car: 1991 Camaro RS
Engine: Stock 305 TBI
Transmission: Stock
Coolant in oil
Well, my coolant didnt drain completely and when i took the intake off some leaked into the lifter valley and who knows where... This is bad. I took a shopvac and sucked what didnt flow downa hole up, and i was thinking i could reassemble the engine and drain the oil, then flush it with a quart or 2 of oil.... Then when i get it started drain and flush it again. Is this overkill or would one flush do it, or do i need to do something else?
Important Q, thanks for any help guys.
Old Jun 10, 2005 | 08:24 PM
zdrag28's Avatar
Car: 85 z28
Engine: 327
Transmission: th350
Axle/Gears: ford 9in 4:56 to 1
you would be alright just draining and changing oil, you could flush it if you want to but it would be alright even if u didnt
Old Jun 10, 2005 | 08:39 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Drain the pan and refill it, then don't worry about it after that. Whatever's left won't be enough to cause a problem before it evaporates off when the oil heats up.
Bubbajones_ya
Jul 6, 2024 08:32 PM
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
92firebirdguy
Sep 1, 2016 07:53 AM
codeysabatini
Nov 10, 2015 04:07 PM
Stryker412
Sep 20, 2015 06:59 PM
