Ride quality? (or lack thereof)...
Old Sep 3, 2001 | 10:15 PM
I ROCK's Avatar
Car: 89 IROC-Z
Engine: LB9
Transmission: 700-R4
Well I'm a poor Indiana boy that just moved to CT just outside NYC and the Iroc's suspension is NOT cutting it. Me and the car are getting rocked to **** by these roads. Should I get new springs or what? I've got all new steering (except the box and pitman) and new struts but kinda old shocks and original springs and bushings. Should I just plan to drive something else or is there a way to smooth out the ride? Does anyone in the area have suggestions? Thanks for any advice.
[This message has been edited by I ROCK (edited September 03, 2001).]
Old Sep 4, 2001 | 07:25 AM
82camaro's Avatar
Car: 82 camaro SC
Install some soft v6 camaro springs and sway bars or trade it for something other than a sports car. Harsh ride is a trade off for good handling.
350 with stealth intake, holley carb, 470 lift cam. 700r4 with .5 boost valve, vette servo, tci lock-up kit, B&M megashifter. Richmond 3.73 gears, powertrax locker, timkin bearings, synthetic lube. Custom 3 inch single into 2 2.5 pipes. 1 1/2 drop springs, 1 5/16 solid front sway bar, 1 inch rear bar, custom subframe connectors, custom LCA relocation brackets. Kobel ground FX, currant red metallic paint. Lots of other stuff...
82camaro
Old Sep 4, 2001 | 09:43 AM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
Between my Sport Coupe, my IROC and my GTA, my Sport Coupe definately makes the most pleasant daily driver. My IROC handles like an indy car, but the ride is reminiscant of a dump truck. The GTA is even worse. The Sport coupe still handles well, is responsive, and rides as smooth and as comfortably as any car I've driven.
I think a suspension swap out of a V8 camaro (non Z28 or IROC) would work nicely. The V6 springs may make it too soft. The non IROC suspension also has smaller sway bars which is going to make a difference too.
The IROC Homepage
<A HREF="http://www.rit.edu/~jli4307/camaro" TARGET=_blank>
View the restoration of an 85 IROC</A>
Custom Thirdgen Subwoofer Enclosures
"I didn't know a bored out Ford could go so slow" -Shenandoah
Pac J
May 17, 2020 10:44 AM
Mark_ZZ3
May 24, 2018 01:02 PM
383backinblack
Oct 14, 2015 08:50 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
wanext
Oct 6, 2015 12:18 AM
