Rear Brake Swap. Help!!!
Old Sep 5, 2001 | 12:56 PM
mystikkal_69's Avatar
Car: 1988 IROC-Z
Engine: L98 (350 TPI)
Transmission: MD8 (700 R4) + 3.42 LS1 Rear
Well people i need help(not mentally). I believe i have all the components and am in the process of installing them. Well i have the standard 88' rear disc brakes(screw in type e-brake). I have heard from many people on the board that they suck. Mine too suffer this condition in which they fail to work. Well i want to put the PBR setup (from an 88' Formula) on my rear and want to know what do i need to make the swap a success. i have the calipers, the caliper backing plate, the rotors, and plus the driver side metal brake line(since it it different from mine). also do i need a another master cylinder? i think it's the disc/drums type master cylinder that is needed. do i need another prop valve? well if anyone knows what i'm missing here or if anyone has tried this yet, let me know. thanks in advance.
88' IROC-Z, 350 TPI, 700-R4
[This message has been edited by mystikkal_69 (edited September 05, 2001).]
Old Sep 5, 2001 | 03:26 PM
Guest
Guest
Posts: n/a
You'll want the cables for the e-brake as well, I'm about 95% sure they arent the same on both setups.
Its an 88 with the PBR calipers? Sounds like someone swapped on that car too..
Old Sep 5, 2001 | 07:30 PM
Car: 1988 IROC-Z
yeah i found the 88' at salvage yard and was suprised to see an 88' with PBR setup. The e-brake cables were different. I was gonna get the e-brakes cables, but they were already gone. thanks for the reply.
Vintageracer
Jan 10, 2020 05:33 PM
Eric-86sc
Apr 3, 2016 03:52 PM
SpaniardV6
Brakes
19
Sep 7, 2015 03:04 AM
kyleb24
Aug 15, 2015 08:24 AM
MustangEater82
Brakes
Aug 11, 2015 07:52 AM
