timing set correct runs bad.
Car: White 25th Anniversary RS
Engine: lt1
Transmission: t56
Axle/Gears: 4:10
Well when the timing is set correctly it pops on start up. when the timing is advanced off the timing tab it starts good but not when its hot. Does this mean its running lean? Its a 366 i might be swapping in a spare 92 bird but i want to test it out first. all stock with a edel carb.
Car: 86 Firebird, 2002 Monte Carlo, 91 v
mine's doing something similar, I'm thinking it maybe vapor lock, I'm going to work on my exhaust and fuel lines, I'll let you know
1992 Trans Am
May 10, 2023 07:19 PM
