Can u install a inline Fuel pump with the old one still in the tank??
Old Sep 6, 2001 | 03:05 PM
Brandog87GTA's Avatar
Can u just take the fuse out of the stock pump and install an inline fuel pump? Or will it not let passage of fuel unless turned on???
Bright red 87 GTA with I have stock 3.27 gears,stock converter,B&M shift kit, TRW forged 9.75:1 pistons,comp cams pushrods, edelbrock valvesprings, 462 camel hump heads with 2.02in/1.60ex redrilled for angled plugs, 3 angle valve job, ported and polished, performer RPM intake, mallory fp regulator, edelbrock 750 CFM carb, hei ignition(new) with 10,000 volt coil,No cat, flowmaster 2 chamber mufflers, hedman full length headers, edelbrock cam with 488/501
Best Run 1/8 mile 8.62 at 84MPH, Consistantly run 8.8's
Old Sep 6, 2001 | 04:27 PM
87tpi420's Avatar
yes you can. it is a flow through design and the new pump will just suck through
87 z28 bowtie aluminum 420small block dry sump crower lt. wt. knife edged crank oliver lt wt rods brodix track 1's super ram intake slp 1 3/4 headers accel dfi art carr 700 r4 3.42 gears ssm sub frame/ladder bars.....other parts on the way ,soon to be finished!! couple more weeks!!!
http://people.ne.mediaone.net/gdm
Old Sep 6, 2001 | 07:11 PM
Birmass's Avatar
Just to be clear. Does it matter whether it's a TBI or TPI pump or are they the same? I want to run an external pump taht was supplied with my new Accel Pro Ram to make sure I get enough fuel.
88 firebird formula - 13.9 @103mph, 2.6 60ft
350 Vortec TBI
214int/224exh, .471int/.491exh
Edelbrock headers
T56 - SIX-speed
open 3.73's
3 inch Flowmaster catback
I love pissing those LS1's off
My Formula
Grant2k
Jul 10, 2018 04:01 PM
theshackle
Mar 5, 2017 06:37 PM
beachrodder
Aug 25, 2015 08:05 AM
justin57
Aug 20, 2015 07:05 PM
AkDrifted
Aug 17, 2015 07:45 PM
