vacuum leak? pcv valve leaK? someone HELP!!
Old Jun 15, 2005 | 01:59 PM
bstieboydp's Avatar
Car: 1987 camaro, 1994 z28
Engine: 2.8l V6 mpfi, 5.7l lt1 350
Transmission: 700r4 in the 2.8, and t-56 6-speed in the z28
today my car started to run like **** below id say 3-4k rpms and if i gave it any little bit o fgas below those rpms the car would just like rumble at 500 rpm range, if i give full gas it is fine, so when i checked for leaks i found one hose to be kinked so i cut it alittle shorter (top of motor left side there are 2 hoses going to it one big one small it was the small one with the issue) and put it back, then i noticed that the thing above the oil cap was sticking up a bit so i took it out and i think that its just floating there cause if i push on it it doesnt sit in right is this the piece someone helppp!!! im gonnna post this as my own thread cuase i neeeeeeeeeeeeeeed to get the car back on the road (again) thanks alot guys (again lol)
Old Jun 15, 2005 | 02:11 PM
bstieboydp's Avatar
another brief stat where is the tstat as my car seems to be running rich someone mentioned that may be the culprit
Old Jun 15, 2005 | 04:45 PM
bstieboydp's Avatar
bumppppppppppp helpppppppppppppppppp lol im stranded
1992 Trans Am
May 10, 2023 07:19 PM
1985chevydude
Aug 20, 2015 12:29 AM
drathaar907
Aug 6, 2015 04:20 PM
