what is the red wire coming from...i have looked through the wiring diagrams
Old Jun 16, 2005 | 09:21 AM
ElementsofSpeed's Avatar
Car: 91 Pontiac Trans Am
There is a red wire from the fuel pump relay. when the key was turned onto run, it was getting no voltage. I believe this is the fuel pump prime wire, but I dont know what the hell it does and how it works. btw, my car still wont start sometimes. VATS is fine. I can hear the relay clicking every time. the gray and green/white wires get 12V, the orange wire gets 12V, the ground is good as I have wired in a new ground. is the red wire not priming my fuel pump? i am getting spark. This is the last straw...If I cant figure this out tonight...this thirdgen is sold. Thanks.
Old Jun 16, 2005 | 09:52 AM
Vader's Avatar
The wire to the pump should be tan/white, not red.
Old Jun 16, 2005 | 11:02 AM
there are five wires that come out of the FP relay. one is red, one is black, one is orange, one is gray, and one is green with white stripe. is it possible that I am looking at the wrong relay? it wouldnt start when i pulled the relay I am talking about. Any help would be appreciated. its on a 91 TA 305 TPI
Old Jun 16, 2005 | 11:08 AM
thirdgen88's Avatar
Car: 1995 Corvette
Transmission: 6 spd Manual
Axle/Gears: Dana 44, 3:45:1
There is an open female blade connector with a red wire on your '91, I think its on the driver's side coming out of the harness. Feeding +12V to that wire should activate the fuel pump (independant of the relay). This is what replaced the pin that used to go in the ALDL port. Dunno if thats what you're looking at or not, but thought I'd put that info out there for ya.
Old Jun 16, 2005 | 11:51 AM
thank you third gen....i am looking at a red wire coming out of my fuel pump relay. I am not sure where it goes...all that I know is that when the key is turned to run, it is getting no voltage. i can not hear my fuel pump prime at all when i turn the key to run...and i know there is not any pressure in the fuel lines.
Old Jun 16, 2005 | 06:08 PM
Petes 84Z28's Avatar
Car: 1989 Firebird Formula
Engine: Internal Combustion
Transmission: Completed
Axle/Gears: ones that turn.
It sounds like you are looking at the right relay.
The red wire is for the fuel pump prime connector; as mentioned above, it's open, and if 12V is applied to it, the fuel pump should run. The orange wire normally has 12V running through it, and is switched when the relay is activated to power the pump.
The fuel pump feed wire became gray in 1990; it was tan/white prior to that.
BRoss99
Aug 10, 2025 05:08 PM
bigben85
Sep 13, 2015 10:12 AM
ZsTransAm
Aug 11, 2015 07:30 PM
L98GTA87
Aug 11, 2015 06:55 PM
mustangman65_79
Aug 7, 2015 09:55 PM
