Now what?????????????
Old Jun 16, 2005 | 11:05 AM
dark scorpion's Avatar
Car: 1990 gta
Engine: 5.7 l 350 v8
Transmission: automatic
Just to refresh your memories, I have had a hard to no start
problem with my 92 tbi bird.
I have tested for spark I get that. I rigged my own noid light but
didn't see it light up. I am going to check that again.
However, when I turned the key it would crank (as usual and not
start), but as soon as the oil pressure got up I would hear and
see a pop from the tbi unit and then some smoke would come
out of it. WHAT GIVES???????????????
Before this is suggested ( I am already pretty sure there is gas
in the tank as well as some fuel stabilizers), I will get my gas can
and put 5 gallons in the tank and try it again.
Just to save some time, when I check for pulse and don't get one,
what "might be the diagnosis? If I do get pulse and it doesn't
fire what would that be?
The fuel pump primes but doesn't shut off. All the fuses are good.
It has a brand new distributor and all the ignition componets are
new.
HELPPP!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Old Jun 21, 2005 | 10:43 AM
Car: 1990 gta
OK.
I put 5 gallons in the tank so I have fuel.
I checked for spark, I have got spark (bright blue color).
I tested for pulse, and the injectors are pulsing. So what's the
diagnosis now???????????????
It still cranks and won't start. BUT, as I crank it, after about
a minute it backfires.
I spoke to an auto techie and he said my timing is probably off.
IS HE CORRECT???????????????????????
Old Jun 21, 2005 | 11:55 AM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
Are the injectors spraying fuel? How does the pulse look? Does the noid light just very briefly come on? Or is it on for a good duration of the firing period?
it could also be the timing, or maybe the motor is just flooded.
Old Jun 21, 2005 | 12:09 PM
rgarcia63's Avatar
Car: 88' IROCZ
Engine: 388 TPI Motown 350 Race block
Axle/Gears: 2.77
Eliminate the guess work.
Disconnect the fuel pump, and crank to get rid of all fuel, or hold it in WOT while cranking so that the ECM initiates a "Clear Flood."
Once it's dried out, pour a little fuel into the TBI, and stay on for a few seconds, if it doesn't start, you'll need to verify the mechanical timing.
Old Jun 23, 2005 | 10:10 AM
Car: 1990 gta
Thanks!
I will test it this saturday.
