proper routing of alternator power wire
Old Jun 21, 2005 | 01:30 PM
19doug90's Avatar
Car: 1990 Camaro
Engine: 355ci
Transmission: TKO-600 5 speed
Axle/Gears: 3.73 10 bolt
I moved my battery to the trunk and i have the power wire off my alternator running all the way to the back of the car, and then have a place near the battery that i have the wire attached so it charges the batter. Problem being i find that it doesnt charge it all that well. How can i properly splice the alternator power wire into the main battery power wire near the starter?
Old Jun 22, 2005 | 02:02 PM
jasman19's Avatar
Car: RED 1986 IROC-Z28
Engine: 350 5.7L
Transmission: TH 700R4
Axle/Gears: 3.23 10 Bolt
I wouldn't splice into that wire for the battery. I would either try a larger wire going from the alternator to the battery or look for a loose connection. Might even see what the resistance in the wire is but I doubt thats the problem. Just some ideas, hope it helps
Old Jun 23, 2005 | 09:30 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Hook it up from the big post on the alt, to the terminal where the battery cable goes on the starter. Use about #8 wire. Don't splice anything, just put it on that same terminal with a ring connector.
Old Jun 23, 2005 | 11:45 AM
19doug90's Avatar
Car: 1990 Camaro
Engine: 355ci
ya thats what im doing, thanks
BRoss99
Aug 10, 2025 05:08 PM
eightsixseven
Dec 16, 2024 01:50 PM
Vintageracer
Jan 10, 2020 05:33 PM
stalkier
Aug 13, 2015 12:59 PM
