Cooling Fan
Old Sep 8, 2001 | 04:04 PM
89cam305's Avatar
Cooling Fan
The cooling fan isn't coming on when the car reaches normal op temp. However, when I turn on the A/C it kicks on. Bad fan switch? All fuses are good under the dash. Are there any fuses controlling the fan under the hood? It's an 89 305 TBI.
Old Sep 8, 2001 | 04:08 PM
Ozzy88GTA's Avatar
Car: 1988 Trans Am GTA
Engine: 5.0 TPI
Transmission: TH700-R4
It sounds like the fan switch. If it comes on with the AC but not the fan switch, and both signals feed the same relay, then it is the switch.
Old Sep 8, 2001 | 04:16 PM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
Ditto
FREE CARFAX Record Check
If you live in Southeastern US, check us out!
South East Thirdgen
GM Master Tech
ASE Master Tech + L1
Savannah, GA
'87 Trans Am
S/D TPI retrofit including functional PassKey,
22# injectors,
Whatever chip I feel like burning,
JET AFPR, Ported Plenum,
TB Coolant Bypass, Custom Cold Air,
SSM SFC, KYB Shocks, Boxed LCAs, Wonder Bar,
8mm Accel wires,
Flowmaster Exhaust,
16" GTA rims,
Corvette Servo,
3.73 Posi
4wheel Disc Brakes
Summit 1-5/8" headers, 2.5" Dynomax catback.
Best 1/8: 9.519@72.74
'97 Bonneville SSE
Old Sep 8, 2001 | 04:23 PM
89cam305's Avatar
Thanks for the quick response!
Old Sep 8, 2001 | 05:37 PM
blue91rs's Avatar
definatly the fan switch. I tested mine by diconnecting the lead form the switch, and grounding the wire to the block, the fan should come on as long as your ignition is in the on position.
Linson
Oct 24, 2025 02:00 PM
sheachopper
Jul 31, 2019 11:27 AM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
Fanatic1074
Oct 2, 2015 03:47 PM
timbuck
Convertibles
Sep 28, 2015 12:31 PM
