Ignition Problems?
Old Sep 7, 2001 | 03:08 PM
Buck268's Avatar
Ignition Problems?
my 1991 Camaro RS (305) recently lit up the engine service light. Code 15 - put in new coolant sensor, then cleared memory (disconnected neg. term. fer 30 sec). When I tried to start it up after reconnecting, the starter and everything worked. I a pretty sure i was getting fuel, but it would not start. any ideas? btw - i did check the connection at bat., it is good. Any help would be great!!
Ok, I have just put a new distrobution cap, new spark plug wires, new spark plugs, and new rotor. It is getting fuel, or atleast the injectors are working (visual), I am getting a spark. Please, if anyone has any ideas, let me know!
[This message has been edited by Buck268 (edited September 08, 2001).]
Old Sep 7, 2001 | 04:21 PM
Bjase's Avatar
Car: 88 IROC
Did you pull the jumper wire out after reading the codes?
88 IROC with cobbled together (not by me)drivetrain, 86 (?) TPI unit on an '83 305,CE subframe connectors, Edelbrock strut tower brace, polygraphite bushings all around...it handles like a dream, but man is it hard to push!!
Old Sep 7, 2001 | 04:32 PM
breathment's Avatar
ok, these will sound stupid and i don't mean to insult anyone. but did u make sure the key was OFF when u disconnected the battery. and this also sounds crazy, but maybe the sensor somehow did something, try disconnecting it and see wut happends. and make sure u have spark from the wires when ur cranking the engine.
- David
88' GTA 5.7L TPI MODS---> air foil, K&N, Shift Kit, 180* therm, TB bypass, Gutted CAT, Flowmaster 80 Series
Old Sep 8, 2001 | 06:44 AM
Buck268's Avatar
thanx fer the responses, but none of those are it. I have tried everything...After read Chilton for a while, I think it maybe in the ignition. I am gonna check all those things today...
Old Sep 8, 2001 | 09:06 PM
Buck268's Avatar
And it starts. For no appearent reason, it started...weird...
Infested
May 22, 2018 11:56 PM
mddaniel
Sep 8, 2015 05:16 PM
Bryan F
Aug 27, 2015 07:28 AM
Bryan F
Aug 18, 2015 02:28 PM
