Code 34 and MAP sensor
Old Jun 19, 2005 | 02:23 AM
blackbeauty's Avatar
Car: 1989 Trans Am
Engine: 1989 305 TPI
Transmission: 700-R4
Axle/Gears: 2.77 10 bolt
Hi all,
I've got an 82 Trans Am and the computer gives me a code 34. I'm sure my MAP sensor is kaput cos when I measure the voltage on the sensor output it doesn't fluctuate at all when vacuum changes and stays at a constant 0.53V. Fortunately the reference voltage is 5.03V so that's OK. Sound like a sensible diagnosis?
What is the GM part number for a suitable MAP sensor for my car? And, where can I get one from that will ship outside of the USA?
Old Jun 19, 2005 | 11:43 AM
Vader's Avatar
By your results, it would appear that the MAP is dead. You should see numbers similar to this:
Any aftermarket MAP should be better than a dead one.
Old Jun 19, 2005 | 05:06 PM
Car: 1989 Trans Am
Pace have one for $48.46 - is this a good price? GM Parts Direct have it for cheaper but they don't ship international.
Old Jun 22, 2005 | 06:03 PM
Car: 1989 Trans Am
I discovered it wasn't my MAP sensor at fault at all. The vacuum hose had come off the back of the carb. I love a cheap fix!
Old Jun 23, 2005 | 02:40 AM
nkstn's Avatar
i had the same damn problem for so long. come to look at it today and pull all the hose off. it had a small little crack. replaced it and car felt great. easy fixes are always great
92firebirdguy
Sep 1, 2016 07:53 AM
BumpaD82
Feb 26, 2016 02:57 PM
3rdgenkindagal
Sep 13, 2015 02:02 PM
64Chief
Sep 12, 2015 08:05 AM
